I have been working on a project motor 1980 merc 40hp and have fixed and replaced and fixed many things. A month ago or so I did a compression test and the upper cylinder was 160 psi and the lower was 160 psi. Then after running it about 30 miles or so in a month I had various issues with it running better in the first 20 minutes of run time and not so good after that. I have since done another compression test and I am reading 60 psi on the upper and 150 psi on the lower which makes me very upset. I noticed the gasket on the side of the block is corroded and looks like the seal is not great towards the top of the motor. Could this cause my compression to be bad or did I ffff up my pistons and rings and such?
Should I replace this gasket before I start to.....cry!!!!
I also heard that engine cleaner may free up the pistons a bit or am I dreaming?
I dunno how this happened if it is the pistons/rings and such, I have the impeller replaced and the pee hole has been peeing well. I used 40:1 mixture once in a few gallons and a 50:1 after that. Least I thought so. Please advise me and tell me what I should do.
