Re: compression check procedure
seakaye, the "ignition" referred to here is the system that generates the voltage required to fire the spark plug and ignite the charge inside the cylinder. Ignition coils generate very high voltage, and with no path for current to flow, you can get a high voltage spike that causes all kinds of damage.
On OMC motors, the kill switch grounds the ignition wire, so pulling the emergency lanyard does the trick...not sure about Mercs.
