Compression check
TPD211
I checked the compression on my 88 Spl. today.<br />It was done on a cold engine, wot, all plugs removed.<br />Facing the prop side of the engine, the right side cylinders were 120 psi. The left side were 125 psi.<br />The plugs looked good, tan center. Gap was checked and was at .30<br /><br />Do these results sound ok?<br /><br />Thanks
reeldutch
Re: Compression check
thats great compression but warm it up and do it again.<br />but their is not much to improve.<br />use good oil and evry 50 hrs a decarb and you should not have any problems.<br /><br />good luck
