For educational purposes can someone please explain compression importance and what it actually means when considering a used motor. I am told that amount of compression is not important....what is important is that all cylinders be close to same psi. For example: You have 2 v6 engines of same year and make. Engine #1 has 110 psi on all 6 cylinders. Engine #2 has 135 psi on 4 cylinders, 130 psi on 1 cylinder and 119 psi on one cylinder. I would think that Engine #2 would be the better motor because more compression = less wear. Which engine would actually be a better stronger motor? Any explaination or comment would be great!
