COMPRESSION LOSS IN #3 CYLINDER
I have a 1987 85hp Force outboard with 135 psi in #1<br />130 psi #2 and only 35 psi in #3 cyl the engine some times runs great and other times it stalls fequently. There is a distinctive knocking sound<br />when at low idle disapears at fast idle. there is a white steam coming from exhaust. boat still has a lot of power although. could it be the head gasket or how could i check to see if it is the compression rings
