Compression numbers
b_lish1966
I checked the compression on my 1987 70hp johnson and this is what is read, 1 and 2 cylinders 125 psi each, number 3 cylinder 115 psi. My question is should I be concerned about the 10 psi drop on number 3. The spark is also good.
Dhadley
Re: Compression numbers
I'd try a decarb and recheck. If you're concerned, pull the head or get a bore scope. You're within the tolerance but it is worth a decarb.
jtexas
clean the carbon deposits out of your engine.
click over to the engine FAQ section of iboats, there's a thread on why & how to decarb.
it's what I'd do - can't hurt, might help.
