Compression ok??
wishihad
Just did a comp check on my 88 70hp 3cyl merc. Top 2 were 105lb bottom was 90lb. Should I be concerned?
tnks
05GlastronSX
Re: Compression ok??
my general rule of thumb is that they should all be within 10-15% of eachother and yours is just at that 15%. try preforming a decarb and see if that brings up compression any. if not, you should investigate further.
wishihad
Tnks
Will try this weekend and report back.
studlymandingo
The numbers seem just a bit low as well. Do a thorough decarb as suggested, and also spray each cylinder down through the spark plug hole with Deep Creep. Let it sit overnight like this. Run it the next day until the smoke clears up, bring it up to operating temperature before checking the compression. You will probably get some higher numbers.
timmathis
Like said above. Give it a good decarb. And retest the compression. You may be O.K..
Tim
wishihad
Tim
Tried to find some decarb @ west marine today but they had none...? Will have to order.
timmathis
Advance auto has seafoam and deep creep on the shelf In most of their stores if you have one in your area. Also you can try NAPA. I'm not sure but AutoZone may carry it .
Good Luck, Tim
timmathis
If you can't find Deep Creep / seafoam. You can try Ring Free or Mercury power tune.
Tim
