Compression on 2004 Yamaha f200 V6
drchpete
Does anyone know what the Compression on 2004 Yamaha f200 V6 should be. I understand the "within 10% of each other" thing, but what are the absolute numbers on say, a new engine?
99yam40
are you going to use a gauge that has been calibrated to make sure it reads correctly?
If not do not worry and just check to see if all cylinders are close to each other
leak down will tell you more
