Compression on 89 Suzuki 140 HP
I'm thinking of buying an 89 Suzuki 140 hp with a jet that was completely rebuilt 6 years ago. What would be the proper range for pounds of compression in the cylinders. Thanks,Mark
hopalong
Re: Compression on 89 Suzuki 140 HP
I'm sure 135 compression is the # for a new or refurbished OB with all cylinders being within 5-8% of each cyl.
My 140 cyl. are 134 +- 3#
My 115 (same block,bore etc.) are about 110 +-per cyl....runs fine.
You dont want a cyl/s extremely lower than the others
Hope this helps.
