Headlight48
- Joined
- Nov 11, 2010
- 15
OK.. new here, hope someone responds. My wife gave me a 14 foot aluminum fishingboat for my birthday. Just the boat. A friend of mine gave me an old motor (5.5 hp) that has been lying around for many years. Looks like crap. upon removing the cowling I noticed the power head underneath looks really clean. I did a compression check (never done this before) got around 40 to 50 lbs of pressure in each cylinder. Put some oil (Marvelous mystery oil) in the cylinders and pressure went up to about 50 lbs. Put more oil in the cylinders and let it set over night. Next day check the compression and it read 69 lbs. each cylinder was close enough to the same that I could not tell if there was any real difference. Tried the test about 10 times with variations of course and about 5 of the times the compression was exactly the same in each cylinder. I read some where that a rope pull engine will show lower compression. Should I assume the the pistons and rings are good and just go for a major tune up or should I consider replacing the rings? Any info will be appreciated and helpful. I have never worked on an outboard motor of any kind or a two stroke. I get it that I need a factory sertvice manual and am shopping for one. Mean time I would like some expert opinions or at least some experienced opinions about what I should be considering. with this motor. I really like the prospect of running the outboard.
Thanks Headlight48
Thanks Headlight48
