Compression on cold engine ?
barrrj
I have a 93 johnson 115 which I cannot get started, What would the compression readings be for a cold engine, in the faqs it says warm engine up, which i cannot do.
Thanks
bignefan
Re: Compression on cold engine ?
I did my test cold then warmed up there wasn't but 2 to 3 LBS difference
jonesg
its probably to ensure the engine will spin fast enough.
As long as the battery is good, I do mine cold anyway.
Never noticed much difference, but seafoam will make a difference.!
GeneH
I would guess something in the 110-125 range and even within 10-15 lbs, the closer the better.
