compression on johnson faststike
Strangeleak
As long as they aren't below 80-90psi or so and within 10% of each other.
bob johnson
they made V4 faststrikes and they made V6 faststrikes... and the compessions #s are a lot different....which do you have?
bob
bob johnson
seems the v4s had compression in the 130s, while the v6s usually only had compression maybe up to 110.......the manual doesn't list compression as best I can tell.... I picked up a 1999 V6 150 hp... and the compressions were 93-95.... after I mounted to the boat I took it to a dealership who put it on the dyno and said it was running at 100% of new...as far as putting power to the prop.......
