Compression on Merc 35
KeltonKrew
Just got my 1986 Merc out of the shop. Broken shift shaft and new motor mounts. The boat shop I take my boat to always does a compression check on every visit. <br /><br />Here are my results:<br /><br />Cylinder 1 = 150<br />Cylinder 2 = 160<br /><br />Are these acceptable numbers? I don't know what the numbers were new or what they should be.<br /><br />Thanks.
ob
Re: Compression on Merc 35
Yes kelton, Those are good .
KeltonKrew
Thanks OB! I didn't have a clue to what they should be.<br /><br />Does anyone know what they are new? I'm trying to figure out if this motor will last a while with proper maintenance. (I know that is a stupid question because of too many factors, but theoretically speaking).<br /><br />What is the lowest number on compression I should be concerned with.<br /><br />I have to make this motor last as I can't afford another one! :D
ob
Kelton, All motors will vary slightly when new , however you can be assured that the reading of 160 is in the upper range of good.165-170 is common for new motor once rings have been properly seated.
KeltonKrew
Thanks. looks like with some TLC, I should be able to keep this thing running for a while!
