I went to check out a 1997 90hp Johnson that was for sale. It has been in storage for two years on a wooden pallet laying on its side. A mechanic told me to check the compression before considering buying the motor. I took out the spark plugs and then turned the engine with some jumper cables. At first check all I could get was approximately 75psi out of each cylinder. I then took a can of WD40 and sprayed down and saturated each cylinder hole. This time the best reading I could get is about 100 on each cylinder. Was this a good test? Is this compression good enough? Any help or suggestions will be appreciated.
