What should i be getting per cylinder on a 1990 Johnson Faststrike 150 hp????
A albass Petty Officer 2nd Class Joined Jun 30, 2004 Messages 156 Mar 3, 2007 #1 What should i be getting per cylinder on a 1990 Johnson Faststrike 150 hp????
K kynolan2183 Petty Officer 2nd Class Joined Mar 3, 2007 Messages 130 Mar 3, 2007 #2 Re: compression per cylinder From what I understand any thing over 100psi is good and look for them to be with in 10% of each other.
muskrat Chief Petty Officer Joined Apr 13, 2004 Messages 445 Mar 3, 2007 #3 Re: compression per cylinder they all should be close to the same numbers as the other ones & not to very more than 15 psi..
A albass Petty Officer 2nd Class Joined Jun 30, 2004 Messages 156 Mar 3, 2007 #4 Re: compression per cylinder I'm getting from 90 to 100 on each one is that satisfactory??
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Mar 3, 2007 #5 Re: compression per cylinder i'd do a decarb and then recheck, on the low side. http://forums.iboats.com/bbBoard.cgi?a=viewthread;fid=36;gtid=1035563
Q Quimbus Recruit Joined May 21, 2007 Messages 2 May 21, 2007 #6 Re: compression per cylinder For a 1990 - I'd say your good. As long as they are even. That's most important.. Mine was approx 90 each cylinder on a 1993 Faststrike & that is ok even though manual says 100.
