I recently bought a 14' Bayliner Capri with a 1985 Force 50 on it. It runs, but when I put it in the water and advanced the throttle it died every time. Checked the compression and it has well over 100 lbs on one and 0 on the other. It also has a leak in the lower unit, letting water in. got a kit for the lower unit. Now I need to know two things. 1: Is it worth fixing, and two; Where should I start looking in the powerhead? I've never seen a cylinder with NO compression. There is no visible damage to the piston through the spark plug hole, the piston does move, a broken ring would leave (I should think) scoring on the cylinder and there isn't any. There is no evidence of a leaking head gasket. I thought a broken reed valve? Any suggestion? I don't want to tear this thing completely apart if I can avoid it.
