Compression Problems with 175 Johnson
thibben
I have 0 compression in the bottom right cyclinder. 90pounds of pressure in the middle right and 30 in the top right. I put oil in there and it did not come up in the top and bottom one. What could Cause this?
Hooty
Re: Compression Problems with 175 Johnson
Zero compression don't zound good. If the engine's running, you might try doing a decarbon treatment,other then that you're gonna have to remove the head and see where all your compression went.<br /><br />c/6<br />Hooty
Dhadley
It COULD be broken rings. Not uncommon on a crossflow (you didnt mention what year 175 you have so it may not even be a crossflow) on the starboard side. Pull the heads and let us know what you find.<br /><br />Also a model number would help.<br /><br />Good luck!
AUGIDAWG
0 compression says to me you have a hole in the top of your piston.<br />Even if you had no rings, you would get some kind of compression, in my opinion.<br /><br />Or, your connecting rod is broken. (don't even think that)
