Compression Problems
thibben
I have a 175 horsepower V6 Johnson It is a 1980 model. I did a compression test and found that two cyclinders on the same side are at 0 compression and 40 compression. I was wondering what could cause this problem a burnt valve or could it be a hole in the piston or even the cam shaft. I also tried the oil trick and noting came up Thanks
JB
Re: Compression Problems
Problems go in the Troubles Forum, Bucklee.<br /><br />I will move this for you.<br /><br />Good luck. :)
