1990 johnson 150....the motor is not on the boat...i tested the compression on all cylinders...they were all around 70...seems low to me...i removed ALL the plugs when i did the test but i didnt seem to get a really strong crank with the battery i was using......then i did the test with 5 plugs in and the tester on the other cylinder and couldnt get a strong crank at all....any input?
