compression reading
laker925
What should the compression read on a 1971 mercury outboard 65 hp 4cyl?
laker925
Re: compression reading
so if they all are arounnd 108 -110 give or take 5 psi that is normal for that motor?<br />I had a 85hp with 125.
Perfidiajoe
All compression gauges will give you a slightly different reading, if they all read about 110 + or - a couple, and you haven't run the motor for a while, that's pretty good. Usually you should do a check warm, with a fully charged battery, & the throtle wide open. Good Luck, Joe
