compression readings for Evinrude 4hp lightwin
raczekp1
Hi.
I'm working on Evinrude 4hp lightwin.
New rings and new( used) pistons.Instaled pistons dont do much play between cylinders wals. Ring end gap 0.15 mm. But compresion after 1 hour run only 90 psi,So what kind of compresion readings someone got in new Evinrude 4hp lightwin or good runing motor?
hardwater fisherman
My 1978 4hp johnson has 110psi on each cylinder. But as you probably know not all gauges will read the same. 90psi is probably acceptable.
nwcove
90 psi is fine. if it was down in the 60 zone, then not so fine.
Crosbyman
all my oldies are mid 70s and up compresssion Wise and work fine especially my 5.5 from 1958.
3hp.4hp.5.5hp 7.5hp
boobie
Compression is fine. As said, all gauges don't read the same.
