Ok so I have a dilema, I set the points (dual points) and was doing the spark test, at first only 1,3 would spark re-adjusted the points and then 1,2,3 spark but not 4.. moved the points a little and 4 sparked but not 1,2,3. re-adjusted it again and got 1,2,3 but not 4 again.... any ideas as to why it will spark alone but not when the rest are set correct? I may be setting these wrong but im not positive. Also could it be a bad ground somewhere?
Also did a compression test with the engine cold since it will not start, 4,3,1 are 90psi and 2 is at 70psi. Did the test twice to be sure. My understanding is that the compression should be at least about 100 could this be because its cold? Does this mean all the piston rings could be worn or that just possibly a burnt valve on 2? I just read about squirting oil into it and seeing if it comes up, what type of oil? just the 2 cycle that I use for the gas/oil mixture?
