compression spec for yamaha 55 1993
schmalts
Hi, anyone have the compression spec for a yamaha 55hp 1993 model? that is the 2 cyl model. I am thinking of buying one but want to test compression before I buy.
any thoughts on the reliability of these motors?
JB
Re: compression spec for yamaha 55 1993
There is no psi spec, schmalts.
Look for the cylinders to be within 10% of each other. Depending on your guage, technique and conditions you might get as high a 120-130 or as low as 80-90.
Good luck. :)
robert graham
Always a good idea to run the motor on the boat, in the river, before buying it. Run it wide open for a few minutes, then at mid-range, then at idle. If it does all these well, then it may be a good motor. Good Luck!
