compression test- 1985 120 mercruiser
jeff13601
I did a compression test today. From one thru four it read 145, 150, 140 and 135. The plugs were all dry but were covered with black carbon. Does anyone know what that would mean?
vipzach
Re: compression test- 1985 120 mercruiser
Look at your other thread, I put a link in there that explains plug reading.
vipzach
This is what I copied from his site about black carbon fouled plugs.<br />Soft, black, sooty, dry-looking deposits indicate a rich air fuel mixture, weak ignition or wrong heat range spark plug (too cold). These carbon-based deposits are conductive, much like oil fouling, and will allow the voltage coming out of the center electrode of the spark plug to track down the core nose rather than jumping the gap. This will result in an engine misfire and further aggravate the carbon fouled condition. Check for correct plug heat range. On fuel injected engines, check for sticking injectors, malfunctioning cold start valves and/or circuits. Also check for correct fuel pressure specifications. On computer controlled vehicles, the "limp home" computer mode will always result in a rich condition. Therefore, it is imperative that you check the operation and condition of the on-board computer system. On carbureted vehicles, check choke and choke pulloff, high float level, and needle and seat condition. On all engines, severe vacuum leaks can decrease manifold vacuum, resulting in a rich condition. Weak and/or damaged secondary ignition systems will fail to spark across the gap lowering combustion chamber temperatures and promoting carbon deposits. This condition could also result from continuous low speed driving or poor cylinder compression.<br /> :D
jeff13601
I saved the site, it was very informative. Thx
BTW,....... The #s Look Excellent.............<br /><br />The Black is from a Rich Mix,...... Worsened by Alot of Trolling.............. ;)
jeff13601
If your home I am going to swing by and drop you off a couple lures
Very Cool Deal,.............<br /><br />Reef Runners are My current Favorite Lures........<br /><br />You can borrow My Tools,..... Any Time......... ;)
