achilles555
- Joined
- Mar 16, 2008
- 111
I'm wanting to do a compression test and check the spark on my 1987 Mercury Classic 50 [45 HP}, and I have a couple of questions. Can I do these tests with the fuel line unhooked? I just replaced the impeller. Could it damage the impeller to turn the motor over several times with no water...without the ears? Could I damage the cylinder walls without the gas/oil mixture running through it?
Lastly, do you guys have any good step by step links/forum posts for checking compression and spark? I ordered the manual, but I,m anxious to get started. Any help is much appreciated. AC.
