Re: compression test-grounding the coil
You can also use a cheap remote starter switch.
Basically a hand-held switch with two wires with clips on each. You jump from the switch/smaller positive wire on the starter/solenoid to + battery. That way you don't have to remove anything nor worry about the electrical system. You don't even have to turn the ignition key on, thus the ignition/distributor/coil isn't even active nor is any fuel pump/injectors etc if applicable. The only thing powered is the starter.
Cheers
