Re: Compression test help!!!!
Pullnit, what I usually do is pull the plugs on all cyclinders. Then squirt a light mist of wd-40 in all the holes (if the motor has not been run), then crank over till you get the highest reading. Repeat on all cyclinders, should all read within 12psi. If the motor is still warm from running the wd-40 is not needed. As long as it is over 105 or so, all I look for is being close to the same. Also ask the owner to let you pull the bottom lower unit drain plug to see what the oil looks like, if milky beware. Loper
A bad day fishing is better than a good day at work
