Re: compression test on yahama 225
Like JB said dont get to paranoid about the actual numbers. The important thing is that all 6 cylinders are close in compression. For example #1 105, #2 105, #3 110, #4 112, #5 104, #6 110. That is good example since the largest spread is from 104-112 PSI. Thats less than a 10% differance. If 1 cylinder was say 90PSI then you would have a problem. You can get compression testers at your local auto parts store for about $30.
