I did a compression check on a 1989 150 VRO Johnson on a 19' grady tournament. on 5 of the cylinders the needle pulsed at each compression stroke, and settled on 90 psi. the number 3 cylinder went right to 85 psi, but did not pulse at each stoke of the piston. What does that mean? Also when I ran the engine, it had a "cough". the engine wasn't warmed up, I was checking the engine with the owners permission, before he arrived. there was also a dark oil coming out of the rectangular openings on both sides of the lower unit where the water runs out. the owner had run the motor that morning.
thanks for any information
