Compression test result question
H2Odog
I have a 96 johnson 50hp. I did a compression check on it today and found the top cylinder at 145psi and bottom at 110. I read they should be within 10% of each other. Honestly I thought the top cylinder was high. Any thoughts or remedies? The reason I did a compression check was I am trying to sell the boat. Other than that it runs great.
javsam
Re: Compression test result question
the engine should have been warmed up to operating temp, prior to taking compression test and when taking test best to have throttle wide open.also battery should be fully charged before test.<br />javsam
reeldutch
i suggest a good decarb.<br />may be 2 or 3 times if you have never done it.
