Ok so I ran a compression test today with a borrowed gauge and it wasn't a screw in you had to hold a rubber boot in the plug hole. Also I dont know if it matters but it was also missing the glass. Anyway the results where 65psi on both cylinders on my 1985 40hp Johnson. This seems a little low but I suspect the tester may be faulty. What are your opinions?
