maineiac5586
- Joined
- Feb 14, 2009
- 817
I bought a 2004 YAMAHA 25 HP 4 STROKE MANUAL START TILLER with damaged lower unit it seems to start easily and REVS UP strongly. I am about to buy a complete 25 hp with a blown powerhead that I want to swap this running powerhead to. Before I buy the one that needs the powerhead I tried to do a COMPRESSION TEST by taking both spark plugs out holding the throttle wide open with tester in one spark plug hole but coming up with 90 PSI. Other cylinder is about the same. I expected a higher number but I read there is a decompression device which might need to be disabled to do this test. Anyone know how to disable the device? Also keep in mind that I can't spin the engine over very fast because it's only a pull start. And I know a leak down test would be more accurate but I don't have that tester right now
