Re: compression test
here's a couple things that'll keep 'er happy:
Water pump impeller, every other year.
Seafoam. an ounce per gallon in the fuel.
Click over to the engine FAQ section of iboats, there's a thread about "DECARB".
Take 'er out & run her hard every 2 to 3 weeks, so gasoline doesn't turn to varnish in the carbs.
Take action at the first sign of performance degradation or any other symptom.
Get a prop that let's it run at the top of the RPM range at WOT.
Get the dings taken out of your prop.
Just a little bit of care, that motor'll still be running after we're long gone.
