compression test
drknute3
I apologize for not being able to find it on here but can someone give me the step by step run down on doing a compression test on a 2000 Volvo penta 5.0?
Also wondering if someone could tell me how they get such different HP ratings in the 5.0 series. Why the 5.0GL has only 220hp, but the GI has 250 and the GXI has 270. All are 5.0 engines.
Thanks
Bill
drknute3
Re: compression test
Found a link descibing the process. Do I need to remove all the spark plugs at once or can I remove them one at a time and check that cylinder?
JustJason
technically your supposed to removes them all at once to increase your cranking rpm......
realistically.... 1 at a time is fine.... just make sure you have a good battery.
Ayuh,....
My Guess is,....
2bbl. Carb,... 4bbl. Carb,... EFI,....
danond
Pull all the plugs, you will get a lower reading if your engine turns over slowly with all of them in. Some turn slowly in general for various reasons and you want to get the best reading you can get.
danond
You're not suggesting....
Naw.
