brother chris
- Joined
- Jul 28, 2002
- 2,063
I want to do a compression test on my 78 55hp rude. <br />The thing is, I've read alot of postings here, and I do have a manual, but gotten confused at bit.<br />To do a compression test, you have to have the motor at normal operating temp, ground the wires to the motor, and do compression test at WOT. <br />Okay, now the question I have is can I do the compression test with a garden hose attachment or put leg in a bucket of water, or do I have to do it at the lake, since it has to be at WOT. Because I have heard that you should not put motor at WOT when it is on a hose. That is correct right? <br />So if that is correct, then do I have to take the boat to the lake to do compression test? I am sure the mechanics don't do that to all the motors they fix. Or maybe that is why the bills are so high?<br />Anyways, can it be done in my back yard in a bucket? <br />Thanks guys
