Compression test
JaguarMan
Have a 97 Mercruiser 5.7 LX 4bbl with a Bravo 1. Have a misfire and was wondering if a compression test can be done with the exhaust manifolds and riser removed? Would sure make life easy.
Ayuh,.... Welcome Aboard,... The compression test can be done, With, or without the manifolds mounted,....
JaguarMan
Thanks that is what I thought but did not want to do it first and get false readings.
Volphin
Take a good look at your spark plugs if you have a misfire situation. Their condition can tell you a great deal.
JaguarMan
I hit a lobster pot buoy and wrapped the rope around around the prop. The engine shut off. When restarted it was running rough and could not get on plane.
