Re: Compression Testing
I would do it both ways. It's well known that you'll get higher numbers with oil sealing the piston. But, you'll never be able to get that much oil around the piston in normal operation. <br />A cylinder that shows a big jump in pressure after oiling is a cylinder that has ring problems.<br />The old time procedure was to warm the engine up to get the pistons up to working temperature, kill the spark, kill the gas flow, open the carb all the way, test the cylinder w/o oil, then w/ oil. <br />With oil, the oil overrides the piston rings and you want to know how well the piston rings are functioning.
