Compression Testing
Does anybody know what the engine cylinder compression should be in a 150/HP Evinrude V6 motor, and would the motor have to be warm to do a compression test?
5150abf
Re: Compression Testing
If you can get the engine hot it gives more accurate numbers but as JB said either is fine, runit of coarse on a hose and ears and don't run the engine over 1500 rpm without a load on it.
Sprky
Run the numbers cold and then hot and post which is higher.
