Compression.. Thoughts?
Yesterday
SO I finally rebuilt every other flippin part of this motor (Merc 850) and here is how the power head looks after running and then cooling down some:
130
145
140
145
I know the other 3 are fine, but how suspect is that #1 cylinder? Would you run it like that?
1nebel0
Re: Compression.. Thoughts?
Sounds like you didn't do the rings if I understand your post....Spray Sea Foam through each carbuerator and the numbers could come back in line...The 130 is on the edge as you don't want much less than 15% difference between the highest and the lowest...good luck
Yesterday
Nope I didn't touch the power head mechanics. Lower unit, mounts, hydraulics, wires etc.
Hmm seems I've read this before. Spray it in through while it's running if I'm right??
Chris1956
There is a procedure where you mix 1 can of Seafoam with 1 gal of 50::1 fuel and run it through the motor, stopping the motor just before you run out of fuel. Let her sit a day and then run "normal fuel" at high RPM to clean out the junk in the motor.
Yesterday
That is not what I had thought I had read, but it sounds quite interesting. Thanks for the suggestion! The idea is to break free any rings sticking into the pistons??
kazek
Follow the procedure and you will be happy boater.yes,idea is to free and burn off any carbon build up that can cause damage to engine.think used/fauled spark plug to give you idea what that can do
Yesterday
After a couple of hours running her and tinkering here and there, had this rig up to 40MPH. after the run and some cool down, a compression re-check (carbs closed) showed 140-150 across all 4. I think I will still run the de-carb procedure because I have the nasty mixed up already, but it was nice to see it come around on it's own. Thanks again to all!!
wired247
The 15% thing is just a good general guideline. If you have 130 lbs compression you have a good ish enough bore and rings. If it improved thats great but I certainly wouldnt kick it out of bed for only having 130 lbs no matter what the rest of the cylinders show.
