Re: Compression to gas
"How much compression does it take to ignite gasoline in a motor? Thank you!"<br /><br />It depends on the engine design and many other factors such as....<br /><br />
Compression ratio - higher compression ignites sooner.<br /><br />
Air/fuel mixture - leaner mixture ignites sooner.<br /><br />
Ambient temperatures - lower temperatures cause earlier fuel ignition.<br /><br />
Running cylinder temperatures - higher cylinder temps cause earlier ignition.<br /><br />
Altitude - lower altitude causes sooner ignition.<br /><br />
Deposites in combustion chamber - more deposits cause earlier combustion.<br /><br />
Fuel octane - higher octane causes slower ignition.<br /><br />
2 or 4 stroke? 4-strokes can usually run higher compression ratios with lower cylinder temperatures and thus pre-ignite (detonate) less.<br /><br />Plus a bunch of other stuff like
humidity, etc.<br /><br />And one more biggy unless you have a HCCI gasoline engine (no-spark, autoignition engine) which you don't....<br /><br />
Spark advance or ignition timing.<br /><br />Remember, pressure is temperature affect each other.<br /><br />So....the compression needed to ignite fuel in your engine could be just about
anything. Only the manufacturer knows what it
must be.
