frankenmerc
- Joined
- Nov 10, 2012
- 50
I have recently purchased 1978 Mercury 1150 that I am bringing back to life,changed all the wires, stator,trigger and switch box and went through the carbs and rebuilt the fuel pump and got her running to discover this on the compression readings.
#1=110
#2=110
#3=110
#4=85
#5=110
#6=110
I have tried several things to rule out stuck rings by spraying PB blaster in that cylinder and letting it set and and spinning it over without starting hoping if it was it would free up with no luck.I am planning on pulling the powerhead to get the bottom cowl off to repaint and thinking I should pull off the port covers to take a look at the rings to see if they are ok or if i have broken one or whatever else might be going on in there.
If I discover that the rings are ok should leave as is or plan a complete rebuild or just change the one piston/rings and hone if needed.
All in all she runs pretty good just concerned about that #4 cylinder,Any thoughts / input would be appreciated.
#1=110
#2=110
#3=110
#4=85
#5=110
#6=110
