Doing routine prep for new season I decided to do a compression test more as curiosity than any operational issues. I have a 1991 Johnson Ocean Runner 150hp. All cyl are reading 100psi with the exception of #3 cyl which is running at 50psi. Test was done with motor warmed up. Engine sounds great no skip would never have even questioned a problem. Now that I have checked.... I sprayed some engine tune up into carb for that cyl last night per instructions on can. Will be taking it out for a run tonight. Hoping that maybe somthing is just stuck, ring, reed? Any thoughts<br /><br />Thanks in advance
