Compression
robertpage101
I know i shouldnt be asking but i couldnt find the year for the boat on any of the web site you all listed with your frequently asked ? but anyways the motor i am looking at is a merc 150 and he say all have 125psi. Is this good and the serial # 8063464266 is what he gave me. Maybe i missed it but i looked at all the sites. Sorry if i did
j_martin
Re: Compression
They should all be in that neighborhood, (110 - 125) and within 10 lbs min to max.
hope it helps
John
robertpage101
Re: Compression
Thank you!!!! My next ? is how hard would it be to replace a evinrude 150 on a nitro 180 91' 16 foot with that mercury 150. It has a 20" shaft. He is looking for another serial # for the year
Chris1956
Re: Compression
Robert, Replacing the evinrude with that merc is a function of the years of each motor. The bolt patterns for the outboards have been standardized as of now, however the older motors were non standard. Look at your evinrude. If it has four 1/2 inch bolts holding it to the boat, it might be a standard bolt pattern. Now c/o the Merc for the same pattern. A ruler would cinch it.
robertpage101
Re: Compression
It does haver the the 4 hole on it (The evinrude) . so where should the plate hit in relation to the bottom of the boat. Is there anyway to know if the 20" shaft will work. The mercury is coming with the boat so i can get all the controls is the steering cables common oldre boats?
Chris1956
Re: Compression
The steering cable should have a common hook up, or will be esily modifiable. Merc controls fix a wide range of motor years, but are incompatable with OMC and vice versa.
Generally, the Antiventilation plate will be even with or just above the bottom of the hull. I would think the Evenrude should be at least a 20" shaft. It might be 25" shaft, which may cause you some grief if the transom is 25" and the merc is 20" shaft.
robertpage101
Re: Compression
How do i find that out on my evanrude or how do i take a tape to it. Thank you. You have been a great help
Chris1956
Re: Compression
Measure from inside transom bracket to A-V plate. it will be about 15", 20" or 25".
