Re: Compression ????
Try a seafoam decarb treatment, see the faq files for the method, I just spray it right into the cylinder and run it, my compression came up 10psi.
Seafoam dissolves carbon on the piston rings.
But 80 psi is ok on big V6's.
2 strokes need to be decarbed every season, if enough carbon builds up the piston rings can get stuck and snap off on the port edges.
