Re: Compression
If just one cylinder stops firing, look for an ignition problem. Especially one related to the throttle position. Don't ignore the spark plugs...try some new ones.
The carburetor feeds both cylinders equally, unlikely that is the problem.
I agree the compression is not likely to be the culprit. That would show up more at starting and idle speeds.
What year is your 15? Any possibility it is getting water in the cylinder? A leaking head gasket will do that, AND lower the compression reading.
