Computer slowdown
ae708
After I installed XP SP2 my connect speed dropped from around 2600 kbps down to around 1700. Has anyone else had this problem? Wonder if SP2 can be removed?
BoatBuoy
Re: Computer slowdown
Start, Settings, Control Panel, Add Remove Programs. Select Windows XP SP2 - Remove. Mine hasn't slowed down. If you just installed it, you might want to wait a couple of days to see if anything changes.
ae708
I installed it a couple of days ago.. I'll give it a few more to see for sure.
Rudderman
I have XP2, no slow down.<br />It could be a shoddy modem or local phoneline problems.
Indymike
I noticed similar slow downs on my comp. after the sp2 install. Hard drives slowed down as well.<br />Must be alot going on in the background with it. I would like to see some info on an uninstall as well.
pjc
I would recommend some research at the MS website. Some typical reasons for system sluggishness is your "temp" folders full of crap. Windows is notorious for not removing .tmp files and the like. For example, my kids 'puter temp folders contained 2.GB of unused file space. <br />For net related stuff, I routinely delete cookies in the "temp internet files" folder.<br /><br />The temp folders are used for installing new programs as well as other tasks. You having just installed the sp2, additional files may be in the temp and unneeded. <br /><br />When I delete temp files I let them sit in the garbage can for a day or two to have the ability to restore any that may be needed. Never have needed to yet, but.......<br /><br />Here is a link to a great Windows help board that is MS recognized. <br /><br /> web page
