Con-Rod question
rcb175
I have benn working on a frozen 3 Cyl. 50HP Merc. (1998). I have disasembled the power head and utilizing quite a bit of 'Release All' and Heat, have managed to free everything up. Problem is, I used a mild metal cleaner to remove the rust from the #3 Connecting Rod. This procedure cleaned everything up, although the metal cleaner also removed the cromium(?) finish on the con rod.....is this a problem?...can I simply replace the roller bearing assembly and re-assemble or do I have to replace the Rod also?. (Rods are kind of expensive).<br /><br />Rcb
alcan
Re: Con-Rod question
Yep, yep and yep. Would you buy that motor with that rod in it?
Chinewalker
Replace the comparatively cheap rod now or the comparatively expensive powerhead later. If the rod lets go, it'll likely take the crank and block with it, leaving you with nothing...<br />- Scott
rcb175
Thanks for the input, I'm now searching for a serviceable Rod.....<br /><br />Rcb175
