JamesCoste
- Joined
- Jun 15, 2003
- 595
The lower part of my driveway that is all busted up and cracked. The part that needs to be repaired is 11' x 36'.
About half of this section is broken into pieces that will be light enough to move by hand. I plan to bust up (with a sledge hammer) the rest of the drive.
I plan to move the busted up concrete pieces to the side of the driveway, dig out about 8" of dirt, and then place the concrete pieces back in hole. I then sandyclay to get some sandy-clay to put on top of the busted up concrete. I will rent a compactor and compact this sandyclay so that the sandy-clay mixture will fill in the cracks of the broken up concrete and make for a firm foundation for the new concrete.
I've formed up concrete in the past, but never had to deal with demolished concrete. I want to avoid the cost and work of hauling off the concrete.
Is this a good plan?
How do I uncracked up the section of concrete closest to the "good" uncracked concrete section without busting it.
Can I get a special blade for my circular saw that will help cut the seam separating the two sections?
