Re: Concrete floor in garage grows salt
Bart Sr.:<br />Check the link included in my post above. You should be able to find out where you can get Xypex from their site (or at least get their phone number to inquire). When I bought it (5 or 6 years ago) it was available directly from Xypex only. But I think I saw it at Home Depot or Lowes last time I was there.<br /><br />Ken:<br />From the Xypex site: <br />"What Is XYPEX? <br />Xypex is a non-toxic, chemical treatment for the waterproofing and protection of concrete. Xypex's primary and most distinguishing performance feature is its unique ability to generate a non-soluble crystalline formation deep within the pores and capillary tracts of the concrete - a crystalline structure that permanently seals the concrete against the penetration of water and other liquids from any direction. Xypex crystalline products are dry powder compounds composed of portland cement, silica sand and many active, proprietary chemicals.<br />--------------------------------------------------------------------------------<br />How Does XYPEX Work? <br /><br />To create its crystalline waterproofing effect, Xypex must become an integral part of the concrete mass. It does so by taking advantage of the natural and inherent characteristics of concrete; concrete is both porous (capillary tract system) and chemical in nature. By means of diffusion, the reactive chemicals in Xypex use water as a migrating medium to enter and travel through the capillary tracts in the concrete. This process precipitates a chemical reaction between Xypex, moisture and the natural chemical by-products of cement hydration (calcium hydroxide, mineral salts, mineral oxides and unhydrated and partially hydrated cement particles). The result is crystallization and, ultimately, a non-soluble crystalline structure that plugs the pores and capillary tracts of the concrete. In this condition, the pores become discontinuous and the concrete is thereby rendered impenetrable by water and other liquids from any direction. The Xypex crystalline process will reactivate whenever water is present." <br /><br />If intereseted, I'd still call Xypex & see how appropriate it is for a garage floor (and also mention the salt crystals you're getting to see whether they may impact use of the product) ...<br /><br />Fixin:<br />See above as to why the concrete has to be damp for this product to work. You actually have to remoisten the concrete several times after the product has been applied. Totally different mechanism of action than a barrier sealant.
