Bought boat at end of June. Have put about 70 hours on so far. I check fluids every time I go out and when I come in. I also check oil cap for condensation. Has always been clean. Today, I changed the oil. Prior to changing I ran the engine for about 10 minutes with the muffs on in my yard. Changed oil, turned muffs back on and ran engine for about 5 minutes more. Shutdown and waited for about 10 minutes, checked dip stick, level was ok. Checked cap, condensation was present. Wiped it clean, put cap back on, let sit for about 45 minutes, and there was some condensation again on the oil cap. The oil I removed had no water. The oil on the dip stick looks fine. Could running with the muffs on for that long do something to cause the condensation? I'm very puzzled. Thanks.
